Leaky Injectors! HELP!
Hey, how it going guys fist i want to thank you for responding and helping a brother out. Anyways heres the scoop, I have a 1988 5.0 GT hatchback with leaky injectors, the injectors have BLUE tops and a Silver bodies, I saw Bosch 24lb injectors that look identical to the ones in my car. The injectors leak a small amount of gas onto the upper intake manifold from the top of the injector, Can there be anything done to fix these injectors? I think not but let me Know. Also, i take it these injectors are not stock with the HO motor. The car has the following mods: KN INtake filter, dual Flowmasters, Blue ford racing plug wires, MSD blaster coil, and ENKI rims. Let me know what I can do about my problem and how dangerous it is to drive it. I am running regular and have been driving it this way for about a month. Thanks Blake
RE: Leaky Injectors! HELP!
i correct myself, the o-rings should be the answer if the injector is leaking from where it meets the fuel rail, i thought you meant there was a leak from the injector itself.(ex. small pinhole on the top of the injector casing)----This is reply after coffee----
