Rockin teh 10holes.
Rockin teh 10holes.
Car was a mess during the pics so f***off!
Just finished the coil over conversion and low and behold, my 17x9's were too much for em.
Inner lip of the wheel was rubbing on the lower spring perch, but!
I can turn once more and...
She now squats like a bitch!
Edit: 10holes arnt there to stay however, Draglites will take their place soon enough.
RE: Rockin teh 10holes.
ORIGINAL: Obsol3te
I can turn once more and...She now squats like a bitch!
ORIGINAL: PRO50SC
Do you mean the rim was hitting the lower control arm when turned too far? One or both sides? Do you know the b/s of the wheels?
ORIGINAL: Obsol3te
So turning the wheel all the way made a pleasant noise.
When I installed my coil overs and put on those very same rims, the same part of the wheel that was grinding on the a-arm, was now hitting the lower spring perch on my new setup.
I now have Tubular A-arms(to go along with my tubular K-member) and with these wheels now no rubbing anywhere occurs.
Old Wheel Specs:
17x9
Backspacing 5.75"
Offset +20mm
