little problem....
Old 05-14-2006, 07:32 PM
BlackMustang02GT
BlackMustang02GT's Avatar
Default little problem....
aight as in previous posts running a 94 5.0 litely modded with headers, h-pipe exhaust. no cats.... spark plugs wiring .... blah blah blah... now i got into a really big accident in july of last year and well rebuilt my car (no harm done to engine except a couple of pullies) anyways i have finally finished repairing it and well a couple of times when pressing the pedal to drive a a normal speed the car would miss an enormas amounts of power... just like choke a little and backfired a couple of times until i press the pedal to the end it would then launch normally, then after a good 10 min of driving it wouldnt do it to me anymore... may i also add that in the accident my h-pipe that was connected to my headers bent a little but i got that fixed and aligned back... but maby it has somthing to do with it? maby the spark plugs? any known problem of this? it has never happened to me before so i have no clue and its pissing me off cause im pretty sure its somthing stupid.....
thanks again...
blackmustang94gt
BlackMustang02GT is offline
Old 05-14-2006, 07:43 PM
203Mach1ne
203Mach1ne's Avatar
Default RE: little problem....
I dont know what the problem is...BUT I like your red calipers
Did you paint them? If so, what kind of paint did you use? I'm going to paint mine red soon..
203Mach1ne is offline
Old 05-14-2006, 07:47 PM
BlackMustang02GT
special high temp caliper paint.... bright red...
Old 05-14-2006, 07:49 PM
203Mach1ne
203Mach1ne's Avatar
Where'd you pick it up?
Spray or brush on?
Old 05-14-2006, 08:08 PM
5.0 MPG
5.0 MPG's Avatar
when was the last time u tunes it up?
5.0 MPG is offline
Old 05-14-2006, 08:29 PM
BlackMustang02GT
its a spray paint.. and well its called CANADIAN TIRE.... (the store name) i tunes it up before i reput my motor in...
Old 05-14-2006, 09:13 PM
Ecstasy
Ecstasy's Avatar
not to change the topic, hey 5.0 mpg what kind of hood is that i like that hood.
Ecstasy is offline
Old 05-14-2006, 09:16 PM
AdderMk2
Banned
AdderMk2's Avatar
ORIGINAL: Ecstasy
ram air... probably cervinis
did you check your timing.... sounds like its probably WAY off
AdderMk2 is offline
Old 05-15-2006, 03:46 PM
BlackMustang02GT
what would the timing do with choking of the car? and then fix itself after about 10min of continuous driving?
Old 05-15-2006, 04:53 PM
collincastaneda
collincastaneda's Avatar
Your computer may be trying to compensate for bad timing.
collincastaneda is offline
Quick Reply: little problem....
