New x pipe = check engine light
Old 05-17-2006, 09:52 AM
1stStang
1stStang's Avatar
Default New x pipe = check engine light
Installed a Bassani x pipe and BBK ceramic headers about 3 weeks ago. Now, from time to time, the check engine light comes on and stays on. I have seen MIL Eliminators for other years to cancel this problem after install of an off road h or x pipe. Does anybody know where I can find this part for a 95 GT? or is there another fix that is out there? Any feedback is appreciated.
1stStang is offline
Old 05-17-2006, 10:17 AM
Joel5.0
Joel5.0's Avatar
Default RE: New x pipe = check engine light
MIL eliminators are for OBD-II systems that use a set of downstream sensors after the cat-con's, these set of O2 sensors don't affect the load tables for the EEC system, they simply check cat-con's "efficiency, and do not apply to your OBD-I application....'94-'95 5.0L are still EEC-IV and do not have the extra set of O2 sensors after the cat-con.
You would have to run a set of DIY KOEO/KOER self-tests to check what the EEC-IV system is logging as failure codes, and id and correct what is causing them. My
Joel5.0 is offline
Old 05-17-2006, 01:19 PM
Ecstasy
Ecstasy's Avatar
check autozone and its because you cut your cats off. friend had that problem after doing it.
Ecstasy is offline
Old 05-17-2006, 07:09 PM
eaturls1
eaturls1's Avatar
jegs sells the elims. check with them
eaturls1 is offline
djbigskrilla
09-20-2022 01:04 AM
labudski
08-24-2015 07:23 AM
microgt
08-20-2015 07:12 AM
mweiland
08-13-2015 05:11 PM
drumhedd2005
08-13-2015 09:59 AM
Quick Reply: New x pipe = check engine light
