spool or lim. slip differential???
Old 05-18-2006, 12:54 AM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
Default RE: spool or gear differential???
31 splines should be fine. Get a driveshaft loop and look into better wheel studs & c-clip elims. Detroit locker will be fine for that HP range. They can handle much more than that. One thing to keep inmind, if you get stronger shafts & diff, that just moves the weakest link somewhere else. Don't skimp on u-joints either, spicers are one of the best.
Grimace5.0 is offline
Old 05-18-2006, 12:57 AM
ikeybmg
ikeybmg's Avatar
cool man, i have alum shaft and fly. tremec tko, and the rear will bout fill me out i think. better wheel studs & c-clip elims ill look into also. and i plan on a loop too. you have to run em with d/rads here. but id rather have a loop even if you didnt have to. i know a guy who flipped a vette and bout got killed when his front U broke!
ORIGINAL: Grimace5.0
ikeybmg is offline
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
2 words "selectable locker"... you can do air or electric or even cable actuated. They work great.
Not to argue, we come from the same "other hobby" but I don't like selectables. LOL
Air operated? on a race car? Too much weight. Cable operated? what happens when the cable breaks? Does it get stuck open or locked? I won't even touch electric....
I know your just offering ideas to the guy.. just messin with ya PG13 Pirate style.
Old 05-18-2006, 01:13 AM
promustanperformance
promustanperformance's Avatar
Powertrax makes a great differential for 31 spline axles, good for both the strip and the street. Check out their Extreme Traction Systems, and their Lock-Right Systems. The Extreme Traction System sounds like it may be the most ideal for your application. Let me know if you are interested in either or if you have any questions, I am an authorized retailer. Happy to help
promustanperformance is offline
Old 05-18-2006, 01:15 AM
Forgot to mention axles. Moser are good, but so are Ford Racing's 31-splines.
Old 05-18-2006, 01:19 AM
ikeybmg
ikeybmg's Avatar
moser or strange. im leaning at the detroit locker kinda. but im up for more opinions
ORIGINAL: promustanperformance
ikeybmg is offline
Old 05-18-2006, 01:21 AM
ZachW04Stang
ZachW04Stang's Avatar
The chassis guy I know throws spools in everything. Street cars, drags cars, you name it. He's told me that a spool isn't going to destroy a streetability of a car that really isn't ment to do anything but go in a straight line. Its going to handle like crap going around corners anyway. You'll be able to do regular street driving but just nothing crazy around turns.
ZachW04Stang is offline
Old 05-18-2006, 01:26 AM
MSU_Aaron
MSU_Aaron's Avatar
Cables the cables for OX's are very stout, air ya extra weight of 3lb compressor. ELockers are very dependable and when not engaged still have "limited slip".
I didn't know Pirate had a PG13 level.... Pirate mode "SEARCH NOOBIE SCUMBAG"
MSU_Aaron is offline
Old 05-18-2006, 01:27 AM
The great thing about the Powertrax is it locks up like a spool in a straight line, but it disengages for going around corners.
Old 05-18-2006, 01:36 AM
Grimace5.0
I ♥ Acer
Grimace5.0's Avatar
LOL No, I cleaned it up for this forum. Fawkin noob
Quick Reply: spool or lim. slip differential???
