afr 185s
05-21-2006, 09:46 PM
afr 185s
whats the maximum valve lift of the springs of afr 185s?
05-21-2006, 09:47 PM
I ♥ Acer
RE: afr 185s
why? as you would want to have the springs set to your cam specs anyway
05-21-2006, 09:50 PM
RE: afr 185s
i want to see if the springs on them will handle my cam as long as the cams lift isnt over the maxz lift on the springs itll work
05-21-2006, 09:52 PM
RE: afr 185s
.540 or you can get the high rev style for 300 more...if i was you tell afr what cam you are getting then they can match it.
Quote:
ORIGINAL: GaryBisiniere
05-21-2006, 09:53 PM
RE: afr 185s
im buyin the heads used for 900 with 500 miles on them
RE: afr 185s
get afr 225s instead of 185s
05-21-2006, 09:55 PM
Banned
RE: afr 185s
Quote:
ORIGINAL: FiveLiterRiceEater
are you serious???? 225s are WAAAYYY too much head for a little 302
05-21-2006, 09:56 PM
RE: afr 185s
im buyin the heads used does any1 know the maximum valve lift on the springs with the 185s?
I ♥ Acer
RE: afr 185s
Quote:
ORIGINAL: AdderMk2
duh bigger is better right? lmao.
05-21-2006, 09:57 PM
I ♥ Acer
RE: afr 185s
do you have a clue?
don't even know what mods he has
