how off is it?
how off is it?
i just finished my 4.10 install now im wondering just how off is my speedo? i know its off quite a bit. also how about my odometer? does that change with the addition of the gears?
RE: how off is it?
if the speedo bounces will that mess with the odometer.
i remember coming out of my friends house, after filling up my car earlier that night and realised my odometer read 66 miles. i go wtf? no way i drove 66 miles tonight but did i? i couldnt remember but my speedo was bouncing.
one of those mysteries
RE: how off is it?
Yes, by changing the gears in the rearend both your speedo and odometer are off. You need to change the speedometer gear in the transmission (not as bad as it sounds) to calibrate for your change. Please reference this tech article for the correct speedo gear you need to get for your application:
https://mustangforums.com/m_1108239/tm.htm
Please reference the following tech article for how to change the speedo gear (includes pictures):
https://mustangforums.com/m_1236295/tm.htm
Hope that helps.
Hope that helps.
RE: how off is it?
if you had 2.73's it's off by 30%
i just did a 2.73 to 4.0 swap and i am using a 6t in the trans (drive gear) and the stock 18t driven gear from the 2.73's (yellow one)
it is still 10% error, but close enuff for now.
20t and a 6t would be perfect
RE: how off is it?
As an example;
Calibrated Gear 2.73
Installed Gear 4.10
Speedo Reading Actual Speed
------------ 0 ------------ 0
----------- 10 ---------- 6.7
----------- 20 --------- 13.3
----------- 30 --------- 20.0
----------- 40 --------- 26.6
----------- 50 --------- 33.3
----------- 60 --------- 40.0
----------- 70 --------- 46.6
----------- 80 --------- 53.3
----------- 90 --------- 59.9
---------- 100 --------- 66.6
---------- 110 --------- 73.2
---------- 120 --------- 79.9
---------- 130 --------- 86.6
---------- 140 --------- 93.2
That is what it would be if your speedo is calibrated to a 2.73. Like others have said, your odometer will be off by the same amount (33.41%) so for every 100 miles showing up on the odometer, you would have actually only have traveled 66.6 miles.
Installed Gear 4.10
