Vacuume line help!
Old 05-24-2006, 10:59 PM
YNotch?
YNotch?'s Avatar
Default Vacuume line help!
In the middle of doing my mods, and I broke some of the vaccume lines coming out of the plug. It is located at the Right Rear of the motor and has 5 different lines coming off it. Different colors as well.
I removed the smog stuff so I know that I will have to plug up a couple up.
If someon can take a pic of there so I can see where they go, or have a diagram I would appreciate it.
Thanks!
Darrin
YNotch? is offline
Old 05-24-2006, 11:06 PM
fordguy17
fordguy17's Avatar
Default RE: Vacuume line help!
i don't think any of those vacuume lines have anything to do with the smog pump.
i know a few go underneath the upper intake manifold.
not much help, i know...
fordguy17 is offline
Old 05-24-2006, 11:10 PM
TENGRAM
TENGRAM's Avatar
i got these at http://www.veryuseful.com/mustang/tech/engine/#Diagrams
TENGRAM is offline
Old 05-24-2006, 11:28 PM
YNotch?
YNotch?'s Avatar
Thanks for the help so far guys.
Attahced is a motor pic from the tips and info section and I circled the vaccume connector that I am referring to. It isn't a good enough pic to see where the lines go to but you will get the idea.
The lines were real brittle and most of them broke while I was working on the mods, and now I can't remember where they go.
Thanks again!
Darrin
YNotch? is offline
Old 05-24-2006, 11:40 PM
TENGRAM
TENGRAM's Avatar
2 of them go to smog stuff(TAD/TAB-valves from TAD/TAB-solenoids)
one goes to the EGR valve from the egr solenoid
one comes from an intake manifold vacuum source(mine comes from underneath the back of the intake)
hope this helps, let me know if you need more details and i'll see what i can do
TENGRAM is offline
mrtrodonet
09-19-2020 03:12 PM
baddog671
07-26-2016 01:20 PM
TCStangerv6
10-11-2015 05:57 PM
Matt's 95 Stang
10-05-2015 07:16 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
Quick Reply: Vacuume line help!
