Economical 4-5 Lug Swap..?..
Old 05-27-2006, 02:21 AM
Bad Karma
Bad Karma's Avatar
Default Economical 4-5 Lug Swap..?..
Did a search and really didn't get the exact info I was looking for so here goes....
Could someone (who's actually done one or knows for sure) post a list of what I could pull from a wrecking yard full of Fords to swap my '90 over to 5 lug?
If at all possible could you list the part/donor car/year of the donor?
It would be nice for us NOOOOBS to search and find a list to take "shopping."
Thanks,
Ivan
Bad Karma is offline
Old 05-27-2006, 02:34 AM
rmodel65
Yukon Cornelius
rmodel65's Avatar
Default RE: Economical 4-5 Lug Swap..?..
83-92 lincoln mark seven front rotors and ranger rear axels or take the whole disc brake rear from the lincoln! also take the front calipers from the lincoln they have larger pistons.
another swap get a 94-95 mustang and pirate the front spindels off of it and the rear disc 5 lug stuff
rmodel65 is offline
Old 05-27-2006, 02:35 AM
primetime5.0
primetime5.0's Avatar
dont do lincoln front rotors 90% of the wheels wont fit, get 94-95 front brakes, and ranger rear axles
i paid 200 for the spindles,100 for front brakes and 60 for ranger rear axles with drums
primetime5.0 is offline
Old 05-27-2006, 02:53 AM
Bad Karma
Bad Karma's Avatar
ORIGINAL: primetime5.0
So...
Entire front brake assembly from a 94-95 (does it have to be a V8 car?)
Entire Spindle assembly 94-95 (V8 or V6 mustang?)
Axles from a ?? year Ranger
Thanks,
Ivan
Old 05-27-2006, 03:06 AM
primetime5.0
can be v8 or v6, check ebay for best prices, or a local forum
Old 05-27-2006, 03:21 AM
5.0 MPG
5.0 MPG's Avatar
Okay I read that you could only use one side for the axels from the ranger? Im not sure if its driver or passenger? I have a real good article on this at work if someone PM's me on Tuesday I will send them the link.
5.0 MPG is offline
Old 05-27-2006, 06:40 AM
boss429
boss429's Avatar
yeah the axels in a ranger are different lengths so you have to use 2 from the same side.
also not sure from which side though
boss429 is offline
boss429
boss429's Avatar
bronco II axels will also work, but same story with the same side axels
boss429 is offline
Old 05-27-2006, 08:50 AM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Here's a link for ya.
http://www.stangnet.com/tech/lug.html
https://mustangforums.com/m_968156/tm.htm
PRO50SC is offline
10-07-2015 07:02 PM
DCole24
09-11-2015 10:50 AM
Fast-Hands
08-19-2015 06:54 AM
Quick Reply: Economical 4-5 Lug Swap..?..
