X or H - pipes
Old 06-02-2003, 05:46 AM
yellow94gt
yellow94gt's Avatar
Default X or H - pipes
I have a question about X and H -pipes. I just had my gt to the muffler shop to hang my flowmasters ( replacing rusted thru strait pipes) I wanted to have the 2nd set of cats removed and was told I couldnt because there was no place to put the air tubes. The result would be back firing and potential damage to my mufflers. The guy said that my best bet would be to get x or h pipes. My question is... do the manufacturers make them with holes for the air tubes to fit?
yellow94gt is offline
Old 06-02-2003, 03:54 PM
P928S
P928S's Avatar
Somethings wrong. Eighter there's soemthing wrong with your car, or the muffler shop is feeing you a line, possibly to get you to buy a second set of cats?</P>
I've run several cars w/ and without the anti-smog air injecton system with out problems. Some legal, some not. No mustangs though.</P>
In the pre-emissions era, none of the cars had the air injection system. The air injection system that is included with the cats is there to reduce emissions. Even with the bestfuel control system, there is some NO, CO,and VHCs (Volital HydroCarbons, partly burnt gasoline.) are created. In the triple element cat, the first just deals with the NO. The first element basicly needs to have a little O2 in the air as possible. The second element is a mix that deals with the CO, and for that element to work right, you need a as large an amount of O2 in the stream as possible. The solution is to use the smog pump to inject the air after the first element. It's not used to prevent backfires.</P>
You see, backfires only occur when you've got too much fuel in the exaust, basicly, your mixture is way rich. If your fuel system, be it a carb, or injection, is controling the mixture right, nearly all of the fuel will be burnt in the engine, not in the exaust system. If you've got backfires, you need to deal with igntion or fuel problems, not exaust.</P>
The problem with running w/o a smog injection system, at least in Texas, is that every car made after like 65 has to have one to be inspected. Before 84, you don't have to have a cat, but you have to have a smog pump, EGR valve, O2 sensor, etc... The way to haveit riged up without cats legaly, is to have a set of holes cut into each exaust mannafolds, or headers, and have the air injection plumbing plumbed to there. Each states emission laws are a bit diffrent, so I'd check with your local inspection agency, and see what you need to have to be legal. California is of course werid.</P>
H pipes or X pipes are suppost to be better for power because of exaust harmonics. When you've got a dual exaust system, you've actualy got 2, slightly odd fireing, 4 cylinder engines. The result is that the cylinder's pulses don'tline up right, and you don't get as much power. Solution, install a H-pipe or X-pipe, and now instead of haveing 2, 4 cylinder engines, you've got a single 8 cylinder engine, and it's suppost to make the pulses in the exaust system more even. Hopefuly resulting in a better sound, and more power. I'm not sold to the concept just yet. I know some guys that swear by it, but I can't vouch for it.</P>
P928S is offline
Old 06-02-2003, 05:58 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
Dude, get an X.
Check out ANY dyno of an X vs an H, the X will always over power the H (if properly designed).
As for the Porsche dude...man, go check out dynos. Find me one that shows a LOSS of power...I dare you.
jeep45238 is offline
Old 06-03-2003, 01:38 AM
P928S
P928S's Avatar
Thats the problem.</P>
I have no dyno sheet confirming that an H pipe, or X is better. As of yet, I havn't installed one,and made a dyno run. I heard ofseveral that have, but ain't no way I'm checking out a couple of 100 dyno sheets that it would take to staisfy me.</P>
X is better, H is cheaper, usualy, but not by much. Get what you think you can afford/need.</P>
Eighter way, he shouldn't have to worry about backfires, w/ or w/o the X-over, or H-pipes. That sounds like the exaust shop makeing something up.</P>
P928S is offline
Old 06-03-2003, 02:36 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
Go search some older issues of Hot Rod magazine.
They did a test on some Olds, H, open, and X.
The X made more power than all of them.
Old 06-03-2003, 03:14 AM
P928S
P928S's Avatar
I don't have hot roder, magazine,how manyOlds, and how many diffrent sets of pipes?</P>
Exauste tuneing can be very complicated bussness.</P>
What works for one car, doesn't work for others. I'm not convinced that the X cross over is ALWAYS better than the H pipes. diffrent mufflers, diffrent levels of back pressure, diffrent shockwaves movein thourgh the system, diffrent mounting points, etc...</P>
But I'm not going to argue with you that H pipes are just as good. I'm saying I don't know, agreed?</P>
But eighter way, straight, X, or H, there shouldn't be a backfire in sight.</P>
P928S is offline
Old 06-03-2003, 11:50 AM
jeep45238
I ♥ Acer
jeep45238's Avatar
It's agreed. But, I'm also looking at different applications, on different motor sizes, number of cylinders, and uses.
Nascar, Vipers, Mustangs, and NASCAR. Everysingle one has gotten gains.
The reason that it works is when the exhaust path from the driver's side bank crosses over, it for the most part goes in a straight line. But when it crosses, it causes a vacume at the junction, which helps to evacuate the next exhaust pulse from the passenger side bank, and it continues on.
Their conclusion was that X pipes are superior to H setups, but the geometry of them makes it difficult to put into most cars. In that case, the H is very acceptable, and still superior to a standard dual setup.
Old 06-05-2003, 06:45 AM
yellow94gt
yellow94gt's Avatar
I didnt think that taking the smog sensor thingies would cause backfiring. I am about to have them taken out any way. The flows that I put on made the car quiet and I dont like it. Maybe removing the cats will make it a little louder for the time being until I get my X's. They are the quietest set of flows I have ever heard. They are 2 chamber 40 series flows and they dont sound nearly as good as the ones on my buddy's 87 gt t-top. I am thinking of just taking the flows off and having straigt pipes. As for emissions, Alabama has no laws or inspections on it, and from what Ive heard there is no intent to start inspections any time soon. Im not really worried about getting a ticket for a loud exhaust either (fringe benefits of my profession i guess)</P>
What would you fellas reccommend for that loud throaty sound? complete exhaust. one of the first things im doing to the car. Only mods currently are huge taylor racing wires (10mm i think) and a k&amp;N 9 inch cone filter which is being replaced tommorrow with a march ram air.</P>
Old 10-21-2003, 04:04 AM
stangfromhale
stangfromhale's Avatar
<FONT face="Courier New, Courier, mono" color=blue size=3>If you want a deep throaty sound, gut out the back of your flows. No turndowns.No tailpipes.If you can lose your cats that will just add to the sound. Try it and I think you'll be impressed <IMG src=smileys/smiley14.gif border="0"></FONT></P>
stangfromhale is offline
Old 10-21-2003, 04:07 AM
Mach1
Mach1's Avatar
Talk about wakin up a dead topic. <img border="0" src=smileys/smiley4.gif border="0">
Mach1 is offline
Quick Reply: X or H - pipes
