White Smoke?
Old 04-17-2004, 07:50 PM
Stinger
Stinger's Avatar
Default White Smoke?
Hey i need some sound advice please . My mustang is smoking and its white and now its running like crap ! Even when i shut it off it will smoke a little. I know this usallys means rings but could a bad rotor and cap make it run like this?
Stinger is offline
Old 04-17-2004, 08:15 PM
bmorrisj
bmorrisj's Avatar
Default RE: White Smoke?
coolant steaming out.... blown head gasket???
bmorrisj is offline
Old 04-17-2004, 08:20 PM
Stinger
Stinger's Avatar
Yea possible but im sure its smoke and not coolant. [sm=smiley24.gif]
Stinger is offline
Old 04-17-2004, 08:31 PM
bmorrisj
bmorrisj's Avatar
coolant+hot suface w/ no pressure= steam....
bmorrisj is offline
Old 04-17-2004, 08:35 PM
Stinger
Stinger's Avatar
im saying its not steam!! Its white smoke ! Thank you for your ideas. [&:]
Stinger is offline
Old 04-17-2004, 08:50 PM
jeep45238
I ♥ Acer
jeep45238's Avatar
Dude, it's a blown head gasket or a cracked head/block. Check your coolant, it probably has some oil, or is brownish and foamy.
Also, coolant DOES burn white.
jeep45238 is offline
Old 04-18-2004, 02:23 AM
TheGmKiller331
I ♥ Acer
TheGmKiller331's Avatar
Coolant or Condensation in the motor or exhaust is WHITE.
Oil or rings will be blue smoke.
And a rich condition will be BLACK smoke.
You sir have a head gasket blown.
TheGmKiller331 is offline
Old 04-18-2004, 01:46 PM
Stinger
Stinger's Avatar
Hi Gm killer i hope your right !! Im gonna pull it apart after church! Well how are those pulleys doing ?
Stinger is offline
Old 04-18-2004, 10:17 PM
TheGmKiller331
I ♥ Acer
If its only at startup on cooler mornings its condensation in the mufflers mine does this for a split second but only when it was warm one day and cool the next and moisture was able to build up.
If its all the time its head gaskets.But dont worry this isnt a big deal.Last time i changed a set it was about 2 hours total and it was running but i wasnt in a hurry either.And if you have access to one a 90 degree air ratchet makes things quick.Just do not put them on with it.Use a high quality torque wrench instead.
The pullies arte fine.They are no where near what they claim and to be honest the only difference is it revs quicker.But hey for 80 bucks im not to worried and wasnt expecting a drastic change.
Old 04-18-2004, 10:33 PM
vfast
I ♥ Acer
vfast's Avatar
**** put some stop leak in it and drive it..
vfast is offline
Quick Reply: White Smoke?
