Just got my first 5.0
RE: Just got my first 5.0
ORIGINAL: 92hatchLX
Cleaning them will do, but I personally prefer to buy new parts. A new set of 02 sensors will run you about 80 bucks, but you won't ever have to buy another set again. I would only do this when you decide to do your exhaust, unless you are keeping the car stock. I really would reccomend bumping up your timing though, it's worth a very good SOTP gain.
Okay so here are some of the things I want to get for the car so far:
Shift Kit
Trans Cooler
02 Sensors
Shift Kit
Trans Cooler
02 Sensors
https://mustangforums.com/m_969165/tm.htm There is a like on how to check your voltage from your TPS...if it is stock, you will probably good, but not a bad idea to look at it. SOTP= seat of the pants. If you replace plugs, just go with autolite 25, don't use platnums, don't seem to work quite as well. Bump you timing will help you car perform, but you will also be required to use premium fuel. I bumped mine to 14* and am happy. Good luck
