WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
Old 06-12-2006, 05:43 PM
Sprayin86
Sprayin86's Avatar
Default RE: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
That's the good side, LOL. Driver's side ground effect doesn't line up so hot. I was 18 though when it went on there with very limited knowledge so I'm lucky it even looks halfway decent
Sprayin86 is offline
Old 06-12-2006, 07:40 PM
stanglx2002
stanglx2002's Avatar
whats the vss I converted my car to mass air and dont remember adding anthing new but the baro.
stanglx2002 is offline
Old 06-12-2006, 08:14 PM
stanglx2002
I tried that idle repair kit on my car and it looks like it doesnt work so I think im going to just take it back off and see If I can fix my idle without it. My idle is starting to stick sometimes but not all the time so I think Im having the same problem as you are
Old 06-12-2006, 08:20 PM
grabbem88
grabbem88's Avatar
what repair kit you talking about?
grabbem88 is offline
Old 06-12-2006, 08:34 PM
stanglx2002
The one from ford. Don't worry about it it doesnt work it just makes things worst
Old 06-13-2006, 10:26 AM
grabbem88
grabbem88's Avatar
ok then wht doesn't speed density use it?
ORIGINAL: Joel5.0
Like TENGRAM said....you may have "solved" the idle problem by eliminating an input used for idle control, load, etc.....think of it as forcing the ECM to run an alternate strategy w/out the VSS input, and not allow the system to compensate....you may want to check this write-up article though.
Old 06-13-2006, 10:50 AM
Joel5.0
Joel5.0's Avatar
ORIGINAL: grabbem88
ORIGINAL: Joel5.0
One word.........vacuum.....lol...no, really......that's the way it was designed by Ford....why?......my ed-guess is that the VSS was added to the logic, due to the idle problems the EEC-IV started becoming famous for + as an alternate way to determine load conditions more precisely, since the vacuum induced signal (MAP) was eliminated....
Joel5.0 is offline
Old 06-13-2006, 10:53 AM
grabbem88
grabbem88's Avatar
if i can find it there was some tech guy stating it's not a must...some guy's ran into problems some didn't.
Old 06-13-2006, 11:30 AM
AdderMk2
Banned
AdderMk2's Avatar
Grabbem.. try this instead.. unplug your IAC and adjust youe idle screw tilkl the car runs. I have mine set right around 850 rpms... only trouble it gives me is a little staslling on a cold morning start. but atleast my idle doesnt hang at 1800 rpms anymore
AdderMk2 is offline
Old 06-13-2006, 11:37 AM
grabbem88
grabbem88's Avatar
it's not that bud.....say you are cruising to a stop sign.you push in the clutch..it hangs at 1100rpm...then it just bumps back and forth from 1100rpm to 500 till you come to a complete stop,then maybe it idles where it supposed to be....mine is set at 850 btw.
Quick Reply: WELL I FIGURED OUT MY IDLE PROBLEM.NOW WHAT?
