Bob weight on stock crank?
Old 06-13-2006, 07:50 PM
pitman86gt
pitman86gt's Avatar
Default Bob weight on stock crank?
what is the bob weight on a stock 86 302 crankshaft. I need to know this so that when i buy my pistons that i dont get some to heavy and excede the bob weight and have to add heavy metal when i have it balanced.
pitman86gt is offline
Old 06-13-2006, 09:33 PM
klapdout
klapdout's Avatar
Default RE: Bob weight on stock crank?
every set of pistons rods w/e are a few grams off from factory, cant tell you exactly what yours are, you should have the crank balanced no matter what, balance is off from factory a bit anyway
also it doesent matter if your bob wieght is heavier or lighter than stock was, you can shave/drill metal out or press heavy metal in to balance in either situation
klapdout is offline
Old 06-13-2006, 10:37 PM
pitman86gt
pitman86gt's Avatar
i know that, but if the pistons i get are heavy and can surpass the bob weight they will have to add heavy metal which gets expensive. so it would be worth it to buy a little more expensive piston if it is lighter and would keep me from surpassing the bob weight
Old 06-13-2006, 10:38 PM
pitman86gt
pitman86gt's Avatar
and im haveing the whole assembly balanced.
myshifter
I ♥ Acer
myshifter's Avatar
Just take it from the pads on the rod and piston
myshifter is offline
Old 06-14-2006, 02:21 AM
pitman86gt
pitman86gt's Avatar
i just would like to know the bob weight. surely someone knows this
mtgldr
02-03-2024 09:00 PM
GPR
12-16-2015 12:21 PM
StalkerGT
09-25-2015 02:41 PM
tramphardrocker
09-13-2015 08:56 PM
09-08-2015 11:50 AM
Quick Reply: Bob weight on stock crank?
