lower control arms
lower control arms
i just ordered some maximum motersports rear control arms. i am wondering how much of a project they are to install.
i have rebuilt my motor so i have pretty good mechanical skills but im just wondering how long it normally takes and
and if anyone had any special tricks
RE: lower control arms
It will take a set of jack stands and a jack. Will be about a hour or so. You just need to remove you sway bar and then the lower bolt and lower it with the jack , remove the spring(pay attention to how it is intsalled), then front bolt(you may have to lower you exhaust to get at it. Pretty easy to do.
ORIGINAL: Twister
no thanks, I don't like to hurt my shocks
ORIGINAL: 5.0stanger
You can get by just letting it hang from the shocks and doing one side at a time, but to each their own.
So, you are saying you have never lifted a car from the frame rails or put it on a lift before?? Sorry to say, but the shocks and struts are what keep them from dropping all the way....correct me if I am wrong please
yup, fraid so^ you can do one side at a time though with 2 jack stands, or if you trust the jack, just one stand will work. my jack has a builtin stop so its like both. but yea, when you unbolt that shock itll come down and you better have a jack under it to catch it or the spring will go flying into the unknown.
