What are the symptoms of bad U-joints?
Old 06-14-2006, 07:41 PM
Twisted
Twisted's Avatar
Default What are the symptoms of bad U-joints?
Just wondering. Thanks.
Twisted is offline
Old 06-14-2006, 07:44 PM
Derf00
Gentleman's Relish
Derf00's Avatar
Default RE: What are the symptoms of bad U-joints?
A loud thump or knock when you step on it coming from the rear, shaking or vibration at freeway speeds while the steering wheel is rock solid and your butt doesn't have a wiggle (steering wheel vibration is the front tires need to be balance, shaking in your seat means it's the rear tires need balancing.
Derf00 is offline
alden918 95 svt
alden918 95 svt's Avatar
there will be a raddiling and
there will be less of a hook up
the car wil not respond for like a fraction of a sec
u will notic it
they are only like $150
for a have way decient one
alden918 95 svt is offline
Old 06-14-2006, 08:18 PM
Twisted
Twisted's Avatar
ORIGINAL: Derf00
Thanks for the replies, folks. So these are my symptoms: First, when I am doing around 70 or so, I get his rhythmic vibration. It sounds kind of like vvvaaaavvvvaaaavvaaavvvaaav. It does it a little at cruise and on decel, but mostly on accel. As soon as I push in the clutch, it goes away. The steering wheel is rock solid--no vibrations. I can't really tell where I feel the vibration, or if I feel it at all. Maybe I'm just hearing it; although it seems like I'm feeling it somewhere. Second, if I am tooling through a parking lot, feathering the clutch at low speeds, sometimes when I push the clutch in, I get a reasonably loud thunk from somewhere. It only happens if I start to ease the clutch out, and then push it back in abruptly in first gear. Otherwise, the drivetrain never clunks--even when getting on and off the gas. Thanks again.
Twisted is offline
Old 06-14-2006, 08:38 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
shifter shaking more than normal or violently for that matter
rmodel65 is offline
Old 06-14-2006, 09:25 PM
5.0 MPG
5.0 MPG's Avatar
I had the same symtoms and it was a combo of bad u joints and a bolt missing from the rear yoke. It got so loose that I ended up snaping the front yoke and a u joint. Do yourself a huge favor and get under there and shake your drive shaft around to inspect. If its the u joints you can buy new ones heavy duty for like $20 each. and its not that hard to replace them.
5.0 MPG is offline
Old 06-14-2006, 10:27 PM
Twisted
Twisted's Avatar
ORIGINAL: rmodel65
Thanks for the replies folks. The shifter shakes, but no more than any other car I've driven. 5.0MPG, I've climber under there and tried to move my driveshaft in any direct, but couldn't. Will bad U-joints always cause the shaft to become loose?
Twisted is offline
2 kwik
I ♥ Acer
2 kwik's Avatar
dyna-spicer makes really good u-joints
2 kwik is offline
Old 06-14-2006, 11:14 PM
FullAuto
FullAuto's Avatar
[Jeff Foxworthy voice] If your driveshaft is resting on the ground, you may have a u-joint problem. [/Jeff Foxworthy voice]
FullAuto is offline
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
UrS4
09-30-2015 10:13 AM
GT350 S550 Tech
09-29-2015 03:29 PM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: What are the symptoms of bad U-joints?
