now what
Old 06-16-2006, 10:49 AM
krd005
krd005's Avatar
Default now what
Ok changed my thermostat and tested did not leak and seems to be working just fine. Overnight I notice a puddle of coolant under my car. I don't think it's the water pump. It seems to be to far up front to be water pump.
My question is: could it be the water pump? If not could you give some advice as to what I should be checking?
Thanks!
krd005 is offline
Old 06-16-2006, 10:59 AM
kevstang87
kevstang87's Avatar
Default RE: now what
Run the car and see where it leaking from. The puddle got there some how so it has to drip from some where.
kevstang87 is offline
Old 06-16-2006, 11:31 AM
krd005
krd005's Avatar
that's the silly thing I ran it and it didn't leak. It sat and it leaks! What is that?
krd005 is offline
Old 06-16-2006, 11:38 AM
88BlueGT
88BlueGT's Avatar
Put a cardboard box under the car and than you can pinpoint exactally where its comming from....
88BlueGT is offline
Old 06-16-2006, 12:35 PM
kevstang87
kevstang87's Avatar
Is it coming from your coolant overflow???? That would make the most sense if you say it does not leak until the car cools down
Old 06-16-2006, 12:47 PM
krd005
krd005's Avatar
which would mean what?
krd005 is offline
Old 06-16-2006, 01:11 PM
kevstang87
kevstang87's Avatar
Meaning when your car cools down and if there is to much coolant it will overflow to the coolant over flow bottle. And vise versa if the car needs more coolant it will come from the overflow bottle. Maybe that pastic bottle has a crack in it.
Old 06-16-2006, 03:31 PM
krd005
krd005's Avatar
ok another dumb question...how full should the radiator be when cold?
krd005 is offline
Old 06-16-2006, 03:47 PM
kevstang87
kevstang87's Avatar
Well, for me I do the opposite. With my rad.cap off I start my car and let it warm up and when the thermostat opens it drops the level then I add and fill the rad. full
