ac delete
Old 06-27-2006, 12:09 AM
SpooledupRacing
SpooledupRacing's Avatar
Default ac delete
on my 87 5.0 I need to do the ac delete the current setup allready has the air pump deleted.. what belt do I need, and do I need an idler in place of the ac compressor to do the ac delete?
I just want to run the alt, p/s pump, water pump and crank.. and if I still need to use the tensioner just tell me how to route the belt, if I need a idler or what
Dave
SpooledupRacing is offline
Old 06-27-2006, 12:26 AM
sgt_pepper17
sgt_pepper17's Avatar
Default RE: ac delete
you'll definently need the tensioner. I've had buddy's do this and they run into the problem of the tensioner pushing the belt into the water pump pully. I'ld consider getting the a/c delete kit. It should come with a ghost pulley. This will prevent that problem from occuring. Also, most kits come with a replacement belt. Good luck.
sgt_pepper17 is offline
Old 06-27-2006, 12:28 AM
fordracing1122
fordracing1122's Avatar
I forget who sells it but it just replaces the a/c compressor with a bracket and an alluminum pulley...
so you can use the same belt...
fordracing1122 is offline
TENGRAM
TENGRAM's Avatar
i used the FRPP a/c delete kit (~$40). anything custom is not worth the headache IMHO.
TENGRAM is offline
Old 06-27-2006, 09:04 AM
SpooledupRacing
frpp?
what brand is that and where can I get one for under 40.00 my current setup is pushing the tensioner into the water pump belt (or within an 1/8" or something.. (no I bought it this way I did not do it lol)
Dave
Old 06-27-2006, 09:39 AM
hardcore91LX
hardcore91LX's Avatar
The kit he is talking about is the ford racing one. it moves your powersteering pump up where your A/C is so the belt easily clears the water pump. It is easy to install and is the best kit to get.
hardcore91LX is offline
Old 06-27-2006, 05:34 PM
SpooledupRacing
is this the one u are refering to??
http://store.summitracing.com/partde...0&autoview=sku
no pulleys or anythign else needed just follow the instructions and I can get a new belt and run my car with no AC
Dave
Old 06-27-2006, 05:42 PM
white93 GT
white93 GT's Avatar
trick flow makes one that moves the tensioner over where the ac pump used to be. works great and was like 30$
white93 GT is offline
Old 06-27-2006, 07:24 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
remember when some foxes didn't come with a/c? pull it off and get the non a/c belt
2 kwik is offline
Old 06-27-2006, 07:31 PM
hardcore91LX
ORIGINAL: SpooledupRacing
Dave
Yeah thats the one. Im running it also and can tell you it is a simple install and works great.
Quick Reply: ac delete
