belt tensioner
Old 07-06-2006, 10:21 PM
HACKGT350
HACKGT350's Avatar
Default belt tensioner
im going to be running a belt on just my crank water pump and alt, do i need a new tensioner or can i still use the same one?
HACKGT350 is offline
Old 07-06-2006, 10:24 PM
89hatch6smt
89hatch6smt's Avatar
Default RE: belt tensioner
stock will work fine
89hatch6smt is offline
HACKGT350
HACKGT350's Avatar
ok cool do you know what size the belt is going to need to be for this?
Old 07-06-2006, 10:49 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
use a string to find out
2 kwik is offline
Old 07-06-2006, 10:50 PM
HACKGT350
HACKGT350's Avatar
ORIGINAL: 2 kwik
thats exactly what i was thinking about doing thanks
Old 07-06-2006, 10:59 PM
ZachW04Stang
ZachW04Stang's Avatar
I don't know how your going to adjust tension because the stock tensioner goes in and not out like you would need it to to run your assessories that way.
ZachW04Stang is offline
Old 07-06-2006, 11:01 PM
HACKGT350
HACKGT350's Avatar
if you ever let the tensioner go it bends back very far im sure it will work if not ill bring the belt back
Old 07-06-2006, 11:06 PM
SpooledupRacing
SpooledupRacing's Avatar
I am preaty sure u have to run a idler for the ac in order to do this sorry to say
Dave
SpooledupRacing is offline
Old 07-06-2006, 11:09 PM
HACKGT350
HACKGT350's Avatar
ill check it out when im at work tomorrow ill take one of the belts off the rack and see how it works
Old 07-06-2006, 11:11 PM
ZachW04Stang
Did you get a manual rack hack?
Quick Reply: belt tensioner
