hp estimation for 408 with 10 psi supercharger
Old 08-24-2006, 02:01 AM
88stangaruu
88stangaruu's Avatar
Default RE: hp estimation for 408 with 10 psi supercharger
if you know what your doing and build it right, im gonna say 550hp and should be good for 10's if you have any suspension mods
88stangaruu is offline
Old 08-30-2014, 04:47 PM
unclebuck
unclebuck's Avatar
i'm having a 410 cubic moter dynoed this week with a vortec supercharger. not intercooled. should be able to tell you the results. the guy who is putting all together says it should be around 550 to the wheels.
unclebuck is offline
Old 08-30-2014, 06:01 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
I would hope it's more than that, considering I made 556 at the rear wheels with just a 306 and 12 psi
mjr46 is offline
Old 08-30-2014, 06:08 PM
bluebeastsrt
bluebeastsrt's Avatar
If it's built right it should be around 500 on the motor before the huffer.
bluebeastsrt is offline
Old 09-04-2014, 08:06 PM
uedlose
uedlose's Avatar
brought this one back from the dead
uedlose is offline
Old 09-05-2014, 06:52 PM
unclebuck
unclebuck's Avatar
ok here's a up date my car made 600 at the wheels with 10 lbs. of boost. non intercooled. the guy said there's still alittle more to get out of it. final numbers in a day or two.
Old 09-05-2014, 07:03 PM
unclebuck
unclebuck's Avatar
do need a little help cant get my supercharger down low enough to fit my hood on. does any body know of a plate that will lower the super charger in the engine bay the engine is all ready about as low as it can get.
Old 06-24-2015, 09:11 AM
Blown408wCapri
Blown408wCapri's Avatar
Lmao! Make 430hp to 550?! Maybe with a couple plug wires pulled... My 408 spun 550 on the dyne without a blower! Those 205s Flow too. Ill get you a dyno sheet soon when my blown 408 is done. But theres alot of guys pushing over 750 on 10psi with similar set ups. Ill post an update when i get it to the dyno. Engine is ready to go in now.
Blown408wCapri is offline
Old 06-24-2015, 09:13 AM
Blown408wCapri
I also think you are going to need a cowl. Unless you make a custom plate or fab something up.
Old 06-24-2015, 12:29 PM
bluebeastsrt
What do you want a cookie?
Quick Reply: hp estimation for 408 with 10 psi supercharger
