tps registering low volts at wot
RE: tps registering low volts at wot
ORIGINAL: aode06
I disconnected the cable it registers, .99 at idle, 4.6 at wot .
I understand the tables of acceptance are .99-1.27 idle low and 4.5 -4.7 wot , in the A9P processor.
WOT is then a set voltage above the idle voltage.
It sounds like you have a firm grasp on the mechanical problem, I just wanted to clarify the voltage range as it is an area of confusion.
jason
well instead of getting a new cable( i know they stretch over time) ill use a bushing , , washer etc , the cookie n warm milk was good by the way, i got the double filled cream kind
this is a simple fix. i had this issue when i first got my pms. it wouldnt register wot in the pms cause the damn cable was so f*cking long the tb wasnt opening all the way.
i have a fox body like you so the plans in this link arent exactly for our cars but you can adapt the idea http://mustangworld.com/ourpics/fcar/99pedals.htm
after doing this mod i was getting about 4.7v at wot and the gas pedle sits even with brake, when before the gas peddle is practically on the floor before you even step on it. what i did exactly is i pulled all the slack out (there is alittle ball at the end of the cable). i folded the line over and stuck a few zip ties on it to hold it folded over. i used 3 zip ties to be exact. works great, no more saggy peddle
Dam that taste just as good as those cookies n warm milk![8D] I think you guys goota try the new double filled cream oreo cookies, thier the bomb , yummy
Im on it !
I used a piece 1/4 inch piece of sylicone fuel line and 1.4 trans line clamp. YEAH ALMOST KILLED MYSELF INTO A TELEPHONE POLE, WHEN ACCELERATOR CABLE GOT STOCK ON MY FLOORMAT BEFORE[:'(]
Im on it !
