Wet Floor
Old 10-02-2006, 06:23 PM
98F150/GT
98F150/GT's Avatar
Default Wet Floor
So I have a 95 mustang Gt with a wet floor and I was just wondering if there is a known place they leak. Do I have to take out the whole rug to find this ?
98F150/GT is offline
Old 10-02-2006, 06:25 PM
Liquid_02
Liquid_02's Avatar
Default RE: Wet Floor
ORIGINAL: 98F150/GT
*batman theme* heater core *end batman theme*
Passenger side I'm assuming?
Liquid_02 is offline
Old 10-02-2006, 06:29 PM
91stang
91stang's Avatar
if it's the heater core your in for some fun
91stang is offline
Old 10-02-2006, 06:33 PM
Liquid_02
Liquid_02's Avatar
ORIGINAL: 91stang
Yuh huh, I did mine cause I could and so I wouldn't have any problems later when I swapped my 92 dash into my 87. What a terrible design Ford did with the heater boxes... Blower motor is against the firewall.. like WTF you have to remove everything just to replace the blower motor... *smack*
Old 10-02-2006, 06:41 PM
93 LX FiveO
93 LX FiveO's Avatar
GM's are the same way
93 LX FiveO is offline
Old 10-02-2006, 06:44 PM
Liquid_02
Liquid_02's Avatar
ORIGINAL: 93 LX FiveO
No they're not.... Never worked on a GM where I've had to pull out the heater box to change the motor, I've owned 4, and work at a shop, all just unbolt from the bottom or back of it, well from what I've worked on anyway.. which is all the mid 90's and older for the most part
Old 10-02-2006, 07:17 PM
nseoi
nseoi's Avatar
if its not that it might be the condensation drain, check to see if thats clogged, happened to my old passat
nseoi is offline
Old 10-02-2006, 08:11 PM
Black Snake
Black Snake's Avatar
Just bypass it unless you drive the car in the winter, or if it gets real cold.
Black Snake is offline
Old 10-02-2006, 08:14 PM
91stang
91stang's Avatar
i thought it was my heater core when my heat wasn't working but i figured out that there was no circuit getting to it. turns out when i took off the heating control panel thingy with the ***** the **** that controls the fan speed was melted completely... not sure at all how that happened
91stang is offline
Old 10-02-2006, 09:15 PM
PONY GUY
PONY GUY's Avatar
where the water on drivers side or pass side
PONY GUY is offline
Quick Reply: Wet Floor
