eratic idle traced to TPS
Old 10-24-2006, 07:10 PM
pdc427
pdc427's Avatar
Default eratic idle traced to TPS
I am experiencing idle problems on an 88 5.0 GT. Each time the engine is cold started, it races at approx. 2K rpm for about 20 sec. and then idles down to about 400 rpm. It barely runs at this speed and will die if either the heat or air is turned on. Sometimes even after warmup, the engine will race between shifts but after a delaywill slow down to that extemely low idle again. I suspected a problem with the Idle Air Bypass(IAB) and after first cleaning it, I checked the solenoid coil resistance and circuit voltage. Both were within spec. If the power to the IAB is disconnected the engine will immediately die. No codes show up. Does anyone have any experience in this area? I am getting baffled. I am going to look at possible problems with the Engine Coolant Temperature Sensor(ECT) and Fuel Pressure Regulator Control(FPRC) but I don't know if this is the right track.
pdc427 is offline
Old 10-24-2006, 07:24 PM
fourfivefour
fourfivefour's Avatar
Default RE: eratic idle
Check for vaccume leaks or a stuck open egr valve.
fourfivefour is offline
Old 10-31-2006, 08:26 PM
pdc427
pdc427's Avatar
Default RE: eratic idle traced to TPS
Problem solved. Checked codes again. Got code 23(throttle position sensor-signal voltage out of Self-Test specification) . Replaced sensor. Idles great now.
pdc427 is offline
Old 10-31-2006, 09:50 PM
wht90lx
wht90lx's Avatar
my idle has been acting up lately as well, I was thinking about just buying a new throttle body that comes with a new tps and kill two birds with one stone.
wht90lx is offline
4cylinderplus2
10-09-2020 07:45 PM
TCStangerv6
10-11-2015 05:57 PM
svfetter
10-05-2015 11:39 AM
69Volunteer
09-30-2015 10:39 AM
MacSerio
09-27-2015 01:05 PM
Quick Reply: eratic idle traced to TPS
