no start no spark...more info
Old 10-28-2006, 01:58 PM
Idrum88
Idrum88's Avatar
Default no start no spark...more info
the car does not start....i got gas in the rails.....but i have no spark...engine rolls over but no fire....im getting 12 volts to the coil but there is nothing coming out of the coil no spark to the dist......i have replaced the distributor...the coil...and the ignition switch......does anyone know if there is supposed to be any volts goin through the tan wire to the coil.....any help would be greatly appreciated
Idrum88 is offline
Old 10-28-2006, 03:01 PM
fourfivefour
fourfivefour's Avatar
Default RE: no start no spark...more info
Are you positive there is no spark at the plugs? Check the inertia switch. The first thing the test procedure says to do is check for codes and repair them.
fourfivefour is offline
Old 10-28-2006, 03:10 PM
Idrum88
Idrum88's Avatar
inertia switch? u mean like the fuel cutoff? my fuel pump whines like normal
Idrum88 is offline
Old 10-28-2006, 03:12 PM
fourfivefour
Yes in the trunk.
Old 10-28-2006, 03:13 PM
Idrum88
Idrum88's Avatar
ORIGINAL: fourfivefour
Yes in the trunk.
my fuel is fine i just got no spark positive
Idrum88 is offline
Old 10-28-2006, 03:15 PM
aode08
aode08's Avatar
classic symptoms of a failed PIP in the dizzy. get a used dizzy.
aode08 is offline
Old 10-28-2006, 03:19 PM
samseed101
samseed101's Avatar
ORIGINAL: aode06
He already replaced the dizzy. Also said that he replaced the ICM. Every time I have seen this in the past, it has either been the PIP, coil, or ignition control module. I mean...there are only so many parts involved in creating a spark...
samseed101 is offline
Old 10-28-2006, 03:21 PM
samseed101
samseed101's Avatar
Wait a sec... do you have a car alarm or some sort of anti-theft device installed? I've seen this happen before when something goes wrong with the alarm or anti-theft device.
Old 10-28-2006, 03:25 PM
aode08
aode08's Avatar
misunderstood the year lol PIP yeah.
aode08 is offline
Old 10-28-2006, 03:31 PM
fourfivefour
ORIGINAL: samseed101
ORIGINAL: aode06
That is correct many things contribute to making spark. Don't forget the crank sensor.
I have the whole test procedure in front of me and it is very extensive. (too much to type)
With all the parts you have replaced you could have paid to have it fixed. You can replace every part in the system but if it is a wiring problem it still wont run.
Quick Reply: no start no spark...more info
