issues w/ my 5.0
Old 03-10-2003, 11:34 PM
spike306
spike306's Avatar
Default issues w/ my 5.0
ok fellas, i thought i was over my fuel problems, but am apparently not. i changed out my 190 lph to another and that turned out to not be the problem. i drove for about 10 min. then it started acting fuel starved again. then i switched to an adjustable fuel pressure regulator, and the same situaton occured once again. this time i let it run for about 20 min. then i shut it off, when i let it cool of for a while, i came back, started it up, and i got the same results as last time.
any suggestions fellas???
spike306 is offline
Old 03-11-2003, 06:07 AM
spike306
spike306's Avatar
another thing , this all takes place after the water temp. reaches about 190-195 degrees(running temp)
spike306 is offline
Old 03-11-2003, 11:01 PM
lloydchristmas
lloydchristmas's Avatar
Spike send me the whole story again and we'll figure this out.
lloydchristmas is offline
Old 03-13-2003, 04:03 PM
spike306
spike306's Avatar
it's definitely something w/the fuel system. i don't know, it kinda feels like something might clogging the injectors. i do know that it not the filter, not the pump, and not the regulator
got any ideas?
spike306 is offline
Old 03-13-2003, 05:41 PM
lloydchristmas
Clean them. and not with that crap you put in your tank. Snap on makes a machine that connects to the rail and cleans them. Its the ****. Find a shop that has one.
Old 03-13-2003, 07:03 PM
spike306
spike306's Avatar
i'm starting to think that it might not be clogged, i think that it's an electrical failier. it feels like when the car gets to running temp. then something electrical cuts off the injectors. what does that sound like?
spike306 is offline
Old 03-13-2003, 07:13 PM
lloydchristmas
Check your coolant temp sensor. Believe it or not they can cause all kinds of problems
Old 03-13-2003, 08:18 PM
spike306
spike306's Avatar
good idea, while i'm at it, i'm gonna check out the throttle positioning sensor
spike306 is offline
Old 03-13-2003, 08:51 PM
92gtstang
92gtstang's Avatar
i had the same problem w/ my 88 gt, it turned out it was vaporlocking!!! i moved my fuel lines a lil futher from my h pipe and mufflers it solved my problem. just an idea
92gtstang is offline
Old 03-14-2003, 08:46 PM
spike306
spike306's Avatar
i checked my fuel lines, and they appear to be fine, but thanks for the idea. i'm now convinced that it was my ignition modual the whole time. we're about to swap it out. i'll keep you guys informed
spike306 is offline
Quick Reply: issues w/ my 5.0
