What SIZE SlickS WILL FIT
I have factory rims of 15 inch and quad shocks on rear
I need to know what size slicks i can get IN BOTH MEASUREMENT TYPES aka 27.5X12.0-15 295 40 15
soon as weather breaks dyno and track[8D]
RE: What SIZE SlickS WILL FIT
it would be wise of you to upgrade your rear control arms and ditch the POS quad shocks... you will get a better launch without them anyway.
but... the biggest youlll be able to go should be a 26x8.5x15, maybe even a 235/60/15
hell i can get two of these with plenty of traction, 235 60 15 for $58 new each with $19.00 shippong of both, sionce im a neighboring state.
thats pretty cheap![:-] and it has a good star rating of 4.5 www.tirerack.com
ok i see the quads leaving lol, I can knock the upper and lower control arm out in an hour or two with a set of performance ones , thicker with stiffer bushings on them.
now, my next question, (ill prob get the slicks tomm ordered) , what ratio shocks setup is recc fron and rear? for handling on street and driving.
I have 70 lbs in rear from subs.
just my fuc(%(*$ luck!!!!!!!!!!!!!
I went to remove the lower and upper arms, and my torque boxes/mounting area IS BEAT UP BAD !!!
How dare ford put such thin metal there!!!!!, Ill have to wire brush the areas , remove the gas tank or cover it with my welders blanket , and weld me in some reinforcements.
I havent even checked the front torque boxes
actually, I might as well sandblast the undercarriage, weld in reinforcements and support braces, I didnt know this dam car flexes like this, they look horrible!!!
When I get on her hard she goes to the left somewhat
