WHATS NEEDED TO CONVERT TO ELEC. w/p
Im thinkin to switch over to a electric water pump. just wondering what is needed to make the switch. Reroute the belt or add a pulley???
[IMG]local://upfiles/10407/76367660D5E142B39C6C1EC970BD2679.jpg[/IMG]
RE: WHATS NEEDED TO CONVERT TO ELEC. w/p
Several of the pumps offer either a idler pulley (which allows you to use the same belt/routing), or no idler pulley.
IF you want to keep the heater for winter, then make sure there are heater hose outlets on the pump.
Also, you will want a controller for the pump. DCC is a good choice. The controller should provide minimal coolant flow while the engine is warming up, but should not allow stagnation of the coolant.
I just purchased a Meziere WP311 for my 410w build. I haven't used it yet though.
I plan on using a DCC controller, unless I find something better in the near future.
jason
jason
also look at upgrading your alternator now if you are still running a stock one. You'll trip out when your headlights start turning on and off by themselves at night time, and your car barely starts up if you make a stop for gas.
Yea you can get elec water pumps that keep your belt in the same place
Also you should be good on your alternater I run a 1200 watt amp on my stock alternater and batter. Ownly on big bass note them head lights will dim a little
dochawk
08-25-2015 08:25 AM
