cobra 70mm maf?
cobra 70mm maf?
hey guys im looking to upgrade my stock maf when i put on the gt40 intake, im getting a good deal on a 1993 cobra 70mm maf, but i wanted to know how it will work on a non cobra? would i be better off just buying a 73mm maf? (anyone with a good deal on a 65mm t/b or a 73mm maf please email me, i will buy)
RE: cobra 70mm maf?
If you aren't using a 93 Cobra computer the 93 Cobra MAF/MAS will not work.
However...
You can buy the 93 Cobra MAF and replace the sensor with one from a 94-95 Mustang. A j/y is a great source.
This would work perfectly!!!
jason
However...
jason
RE: cobra 70mm maf?
ORIGINAL: vristang
However...
jason
However...
jason
RE: cobra 70mm maf?
I would just buy the 73mm MAFfrom some company that is calibrated to ur size of injectors.Because otherwise the cobra 70mm MAF is calibrated to I believe 24lbs injectors to where yourinjectors if stock, should be 19lbs I think?
RE: cobra 70mm maf?
ORIGINAL: Js04sILVerBullet
wow your misinformed.... ford maf's arent calibrated... the computer has the injector slopes tuned into it... the aftermarket maf's that everyone loves so much.. LIE to the computer...
get a 94-95 mustang 70mm maf
RE: cobra 70mm maf?
ORIGINAL: AdderMk2
of you could just use the entire 94-95 maf
ORIGINAL: vristang
However...
jason
However...
jason
Not sure on that though...
jason
RE: cobra 70mm maf?
ORIGINAL: 2 kwik
ok, let's see...
ok, let's see...
ORIGINAL: AdderMk2
Here, take a look at that Chitown Racer posted.... hes dead on with his info, and can explain it better than I can!
https://mustangforums.com/fb.asp?m=2689362
