another dumb question!
sorry I have another qusestion.imlike 99% sureits right,but is it possible to install the timing chain in more than one posistion?I just cant get my motor to fire up and am looking at every option[:@]
RE: another dumb question!
Depends what you mean. The cam sprocket will only go on the cam one way, and the crank sprocket will only go on the crank one way. However, you need to line up the dots that should be on both the cam and crank sprockets. Make sure you're as close as you can be by putting them as close as you think they go, then moving one of the sprockets one tooth over on the chain, back to neutral, then one tooth to the other direction. You'll see if it's perfectly lined up or not
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
