1995 mustang cobra couple major problems!!!
RE: 1995 mustang cobra couple major problems!!!
i dont get it, you have the ability to install a clutch and trans, but you don't know what o2 sensors do.
and you obviously can't figure out where to look for a no-crank situation.
[sm=dontgetit.gif]
[sm=dontgetit.gif]
ORIGINAL: mattdel
[sm=dontgetit.gif]
[sm=dontgetit.gif]
Vehicle Speed Sensor (VSS)
The Vehicle Speed Sensor (VSS) is a small signal generator that is turned by a gear inside the transmission assembly. The Vehicle Speed Sensor produces 8 pulse per rotation which a stock computer assumes 8000 pulses per mile. The Vehicle Speed Sensor (VSS) is a variable reluctance sensor that generates a waveform with a frequency that is proportional to vehicle road speed. When the vehicle is moving slowly, the sensor produces a low frequency signal. As the vehicle speed increases, the sensor produces a higher frequency signal The Vehicle Speed Sensor (VSS) supplies this signal to the components that require vehicle speed information including the speed control amplifier for cruise control equipped vehicles and computer. The computer uses the VSS signal for emmisions contol programs and speed limiters. The emmisions programing can cause a manual transmission vehicle to stall out while decelerating if no VSS is used.
"If you don’t run a VSS you can run the risk of stalling when slowing down from over 1500RPM."
Did you make sure this was hooked up and or working properly?[/align]
i bought a brand new vss, and the speedo still dont work how can u check to see if the sensor is working properly... by the way i found the problem it was the clucth starter switch..
