Rear bumper
Old 08-02-2003, 05:47 PM
SlimPickens
SlimPickens's Avatar
Default Rear bumper
Hey all i need a little help. Im removing my rear bumper and there is what looks like to me the gas pressure release hose that attatches to the bottom of the rear bumper. I am curious of how to remove it and i am also curious if someone could tell me about removeing the rear bumper period. thanks</P>
</P>
SlimPickens is offline
Old 08-03-2003, 03:26 PM
n2o44
n2o44's Avatar
Default Rear bumper
there are some bolts inside the quarter panel, inside the trunk way down on each side bout three , then all the ones that go across the tail lights , then the push pins on the bottom and you should be able to pull just the cover . oh yeah theres a tube for the gas door that drain fuel if u spill it in there . dis connect it too</P>
i assume your talkin about a fox ?</P>
n2o44 is offline
Old 08-03-2003, 10:29 PM
Buzzstang
Buzzstang's Avatar
Default Rear bumper
THEY ARE NOT ACTUALLY BOLTS JUST NOTS THAT YOU WOUD BE REMOVING. I WOULD REMOVE THE PUSH IN CLIP ALONG THE BOTTOM FIRST SO THAT YOU DONT BEND AND CRACK THE PAINT ON THE BUMPER THE INSIDE THE TRUNK REMOVE THE NUTS 3 ON EACH END AND I THINK 5 OR 4 ACROSS THE TOP. THE GAS OVERFLOW TUBE WILL JUST PULL OUT OF THE LOWER BUMPER.
Buzzstang is offline
Old 08-04-2003, 03:04 AM
n2o44
n2o44's Avatar
Default Rear bumper
</P>
soorrry ,<IMG src=smileys/smiley19.gif border="0"> nots lol </P>
n2o44 is offline
Lethaldosage423
10-19-2015 12:12 AM
uedlose
The Racers Bench
10-01-2015 08:31 PM
lincolnshibuya
09-24-2015 10:46 PM
Sparks_88
09-08-2015 01:06 PM
09-01-2015 08:16 PM
Quick Reply: Rear bumper
