Help! Need to find TDC with no distributor or piston stop.
RE: Help! Need to find TDC with no distributor or piston stop.
ORIGINAL: Joel5.0
Yes....but he needs to make sure #1 is @compression to install the dizzy pointing to #1.......
ORIGINAL: AdderMk2
apparently you dont read
any time the piston reaches the highest point in the cylider .. its at TDC top dead center... it has nothing to do with the valves
rotate the motor and align the crank marker to 0... if you have a valve cover off, make sore one of the valves is open
ORIGINAL: Evil_F
So I guess that the top of the exhaust stroke is TDC.? Just trying to verify if anyone knows.
I have fixed the dizzy and now I need to put it back in.
TY, positive it is the compression stroke?
Anyone know what size socket the crank shaft is? I dont have one that size. All mine are too big or too small. So I am going to have to go and get one. [>:]
PS: I also found somewhere else where they say it is the compression stroke. TY
jaiidutch
09-14-2015 10:29 AM
