tranny problem
#31
RE: tranny problem
newb question here but where do i access the clutch so that i can adjust it. i usually have a friend that helps me with all my mechanical woes but i thought i could tackle this one.
#33
RE: tranny problem
yea that doesnt usually work... what you do...
push the pedal w. ur hand... youll see between the gas and brake a yellowish plastic hook shaped piece moving up w. the pedal, somehow hold it up(i use the *** end of my butterfly knife, simply because its always there, lol use whatever tho) and pull the pedal back toward you SLOWLY, youll hear a click... try one click, if it doesnt feel right, go w. 2... but 1 should do it
as for reverse, its not syncro'd, so throw it in a forward gear then R and ur be fine, we all have to do it.
but ok its in every gear i vote clutch hands down, try to adj it, and consider looking in to an aftermarket cable/quadrant, and possibly a clutch
jaiidutch
09-14-2015 10:29 AM
