Super alloy gear set for T-5
Old 02-25-2007, 08:48 AM
J95SNAKE
J95SNAKE's Avatar
Default Super alloy gear set for T-5
Ok, whats the story with these T-5 gear sets? I see them advertised but whats the advantage/disadvantage? I am putting down 340rwhp 350ft./lbs. of torque. I autocross my Cobra and rarely see the drag strip. I never powershift either. I would like to stay with the T-5 set up soley for cost reasons and the wife...lol. Anyone?
J95SNAKE is offline
Old 02-25-2007, 09:18 AM
burntpiston2007
I ♥ Acer
burntpiston2007's Avatar
Default RE: Super alloy gear set for T-5
go for it
burntpiston2007 is offline
Old 02-25-2007, 11:22 AM
stang8689
stang8689's Avatar
i think the t-5 Z would hold up fine. I just bought a brand new one for my stang. The super alloy gears are what they use plus improved synchros and bearings
stang8689 is offline
Old 02-25-2007, 11:36 AM
92GreyGT
92GreyGT's Avatar
If you aren't going to power shift then the stock T5 will be all you need. I am making more power than that and I ran a stock T5 power shifting for a long time. I changed to the better gears for the higher first gear ratio.
92GreyGT is offline
Old 02-25-2007, 12:30 PM
craigwhite89gt
craigwhite89gt's Avatar
ive been looking into trannys and gear sets for a while... And after talking to the owner of Astro performance warehouse Im going to get this.. http://www.astroperformance.com/prod...roducts_id/207
craigwhite89gt is offline
Old 02-25-2007, 12:46 PM
92GreyGT
92GreyGT's Avatar
I have that kit in my transmission and it works great. If you have a big cam in your car I would suggest you get the aftermarket fifth that Astro sell to give you a .80 OD.
92GreyGT is offline
Old 02-25-2007, 01:24 PM
Arno
Arno's Avatar
I have beenwondering the same thing, some say the high alloy are more prone to cracking than stock. Not sure if this is the case. The high alloy T5's are rated for more HP so why would companies use weaker gears?
Arno is offline
Old 02-25-2007, 01:26 PM
HACKGT350
HACKGT350's Avatar
just wait for lenny to get in here he will set you straight with what you need and the super alloy gears are stronger but are brittle at the same time and can shatter as he has told me and get the stock first gear trans 3.55 not the 2.73 or what ever it is
HACKGT350 is offline
Old 02-25-2007, 01:35 PM
craigwhite89gt
Go with Astro's he told me that kit will hold the power im going to put down to the wheels. 500+ As long as your not just running it down the track it'll be fine and thats all i needed to know. Plus good business and stand behind their product
Old 02-25-2007, 01:39 PM
Scout2232
Scout2232's Avatar
ORIGINAL: HACKGT350
3.55's and 2.73's are rear end ratios, you must be thinking 2.95 vs 3.35
Scout2232 is offline
Quick Reply: Super alloy gear set for T-5
