checking clearances
Old 03-02-2007, 08:25 PM
LIL D
LIL D's Avatar
Default checking clearances
how hard is it to check the clearances when building a motor and what is the best thing to use to do so
LIL D is offline
Old 03-02-2007, 08:26 PM
Pearlkobra12
Pearlkobra12's Avatar
Default RE: checking clearances
/k
Pearlkobra12 is offline
92hatchLX
92hatchLX's Avatar
plastigage. You can find it at autozone and other parts stores.
92hatchLX is offline
Old 03-02-2007, 08:46 PM
LIL D
LIL D's Avatar
thanks
LIL D is offline
Old 03-02-2007, 08:49 PM
fordstroker
I ♥ Acer
fordstroker's Avatar
plastigage is far from the best, its adequate for alot of people, but it cant tell you if theres any taper, also plastigage gets old and will affect readings
fordstroker is offline
Old 03-02-2007, 08:50 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: 92hatchLX
would that be the same kinda stuff you can use to clay the pistons? or is that to measure something else?
OnyxCobra is offline
Old 03-02-2007, 08:58 PM
fordstroker
I ♥ Acer
ORIGINAL: OnyxCobra
ORIGINAL: 92hatchLX
its to measure main and rod bearing clearances, BUT this is a prime example of why you among MANY others on this forum should not be giving advice. Your telling guys what are the "best" heads and have no clue whatsoever what plastigage is, which is the most basic tool for engine building. If you do not have direct hands on experience then you really should not be giving advice. This place cracks me up.
Old 03-02-2007, 09:12 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: fordstroker
ORIGINAL: OnyxCobra
ORIGINAL: 92hatchLX
mmmk. Since when does measuring bearings have anything to do with what makes a good head? Obviously I'm agreeing with the majority of the people here so I'm probably not wrong. I was not giving advice, i was giving my opinion.
Old 03-02-2007, 09:22 PM
LIL D
LIL D's Avatar
im rebuilding my motor and was just curious to know if its something i wanna pay someone to do or do it myslef
LIL D is offline
Old 03-02-2007, 10:52 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
nothing ready beats mics.....you can find them cheap..I also do use plastic gauge..what ever you do while using it is DON'Tturn the crank or rods
2 kwik is offline
Quick Reply: checking clearances
