anyone know if this will work? (smog delete) w/ pics
i found this on some other stang forum just wanted to get other opinions on it, i was plannin on runnin the 70.5" belt on there
[IMG]local://upfiles/41517/315A316F906D4096B20FF1CCC4F13832.jpg[/IMG]
RE: anyone know if this will work? (smog delete) w/ pics
is smog delete for an 94-95 5.0 the same for an 87?
and if i move the PS to where the AC is in that diagram will i need a little bigger belt since it looks likt the pulley is a little bigger?
you can also take your tensioner pulley off, drill another hole, too place it in a better spot, then you can run the belt anyway you want.
thats what i did on 2 of my cars, so you dont have to buy any special pulleys or other crap.
ORIGINAL: deanzawistowski
dont take neones word on belt size tho... no offense but they could be wrong... as for fox and sn95 accesories there different.. that is the bolt on differently and u cant have even be and inch off hte correct belt size... here is what u need to do... take some string... a string that doesnt make much much if ne elasticity... run it thru as u would your belt cut it and hte take a yard stick or tape measure and measure it... thats the length u need... make sure u get the rite number of ribs on the belt as well... stock is 6 so there is a very good chance ull need a 6ribbed belt as it seems u are a lil new to it i doubt u have moved up to an 8 ribbed set it
gl
jaiidutch
09-14-2015 10:29 AM
