86 5.0 in a 88 GT
86 5.0 in a 88 GT
We just baught a 86 5.0 motor out of a Bronco to put in my 88 mustang GT cause other one went boom. so im switching wiring harnesses, oil pan, and intake all from the other motor. and im doing putting on headers and valve covers on it and i was wondering if i bought a Chip for it would it workwith the 86 motor??
RE: 86 5.0 in a 88 GT
thats no 5.0 h.o. its gunna be a big heap every mid 80's 5.0 5.8 litter engines on trucks i have seen have been rusty and nasty and just a bitch to work with and usually real smog pigs
ORIGINAL: HACKGT350
I know its not a H.O the Whole motor was rebuilt and it only has 8,000Km on it since it was done.
Anybody know whats in this motor and how big the difference is between H.O and non-H.O
the difference if about 50hp less and probably about 20-30ft-lbs of torque less then the HO. the heads are crappy E6 headsand if it still has the stock styleTrue flat top pistons you cant chage the heads or cam unless you flycut youre pistons or change them out to ones with valve reliefs. plus the regular 5.0 has a different cam and a different fireing order. trust me.. youre car will feel like a fox with a v-6 in it after you change the motor if you go to a non HO motor. not worth the time in labor to put it in.
ORIGINAL: ooticamitica
difference is firing order and i think cam/intake you mineswell just go h/c/i get a new computer and dizzy/ignition edit.. i thought 84 was flat top?
