Car runs better when cold? Or am I just crazy?
#21
RE: Car runs better when cold? Or am I just crazy?
When the engine warms up, cylinder bore gets larger asdo the rings like you said. But when the rings are worn and cylinder bore is worn the cylinder bore expands enough that even when the rings expand they do not completely seal. Allowing more blow by.
#22
Bore expansion over the course of even 300 degrees would be pretty minute. Fractional expansion of iron is only .0000067 per degree F. Aluminum is .000013. Compression ring gap limits for a 4" bore engine is .01 to .02 inches. To widen that gap to .03 or higher would require the bore to expand by .0095 inches.
http://hyperphysics.phys-astr.gsu.ed.../thexp.html#c1
#24
WhenI have installed rings on my engine builds, I have had to compress the rings a fair amount to get them to fit in the bore. I would think the bore would have to be about 4.25" for the ring to no longer touch the walls.
#26
In my experience, it takes a lot of blowby/loss of ring seal toproduce even a small power loss. Either way, if he's hard on the throttle, those piston rings are flared hard against the cylinder walls. Also, I though that as an engine heats up, the pistons are what do most of the expanding.
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
