Stang out from winter and won't start
Old 03-11-2007, 04:01 PM
Madskillz306
Madskillz306's Avatar
Default Stang out from winter and won't start
hey guys, i'll get right to it, my mustang was parked for the winter outside covered etc etc nice out today in ont canada and i decided to start her up and she won't fire. I drove and parked there fine and she is rolling but won't fire no spits no sputters. fuel primed and checked at fitting. any ideas as I really wanna hear it run and wake up for the year.
Madskillz306 is offline
Old 03-11-2007, 04:07 PM
Madskillz306
Default RE: Stang out from winter and won't start
anyone? Help a fellow stang guy out here please.
Old 03-11-2007, 04:12 PM
w8less
w8less's Avatar
u have to wait more than 6 min for someone to help you out.
is it cranking at all?
w8less is offline
Old 03-11-2007, 04:14 PM
Madskillz306
ya she cranks and rolls over fine but no hits no bumps no spits no sputters etc etc.
Old 03-11-2007, 04:17 PM
w8less
w8less's Avatar
so its cranking but doesn't completely turn over?
w8less is offline
Old 03-11-2007, 04:29 PM
mustangfxbdy
mustangfxbdy's Avatar
are you getting spark?
mustangfxbdy is offline
Old 03-11-2007, 04:31 PM
Madskillz306
k maybe i'm not explaining it right, it completely rolls over and i can crank it all day but nothing. she cranks and rolls over fine but no hits no bumps no spits no sputters etc etc. I dunno how else to put it. nothing else was removed over the winter. all connections fine and have been the same since i parked it. I checked fuel primed and lots of pressure at the fittings main distrub cable connected and all plug wires of course arecorrect the rotor inside and points cleaned inside and out Solnoid connections ok. she won't get any sotta hits/bumps/spits/spudders unless i pretty much flud it in which i shouldn't have to do 91 gt efi, key turned back and fowd multi time to insure the pump and lines primed to max etc.
Old 03-11-2007, 04:36 PM
Stanpower
Stanpower's Avatar
Troubleshooting Intermittent Engine Problems, Larry Carley, August 2003
Stanpower is offline
mustangfxbdy
id check to see if shes getting spark to the plugs.. if so then id pull plugs and check condition of them make sure there not fouled... also what type(octane)of gas did you put in it before putting it down.... also did you start it at all this winter....
Old 03-11-2007, 04:38 PM
Madskillz306
i knew that was gonna come up also my bad, whats the easyest way to check just a screw driver in #1 and bump her until it hits that cyl and see if she gets spark. problem is i only had me and my gf here so wasn't able to check and roll/bump car over and i think the gf would over crank it. etc.
Quick Reply: Stang out from winter and won't start
