Heads?
Old 03-12-2007, 03:50 PM
89gfoxlx
89gfoxlx's Avatar
Default Heads?
With the car in my sig and the mods listed if I added gt40p heads, what kind of hp gain would I see? Would it do much without adding a cam? Which would be a good cam? I was thinking maybe tfs 1. I would like a cam that makes power and is pretty lopey. Also would I need to up the injectors and maf? thanks
89gfoxlx is offline
Old 03-12-2007, 03:59 PM
r.barn
r.barn's Avatar
Default RE: Heads?
+40hp with the heads
yes cam will help. TFS 1 cam is not bad, but custom cam is better. Ford E cam not bad either.
You dont HAVE to do a cam swap, but it will only help.
stock injectors are fine.
76mm C&L MAF would be good upgrade.
might want to upgrade to a 155-190 lph fuel pump too.
r.barn is offline
Old 03-12-2007, 04:03 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
what cam would make it run well and have a nice lope?
89gfoxlx is offline
Old 03-12-2007, 04:08 PM
r.barn
r.barn's Avatar
Default RE: Heads?
look for a cam with bigger durration for lope.
a Ford B cam would probably make you happy or TFS 1
r.barn is offline
Old 03-12-2007, 04:17 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
one more question. Should I have the heads and my cobra intake ported and polished or would it make much more diff? and with heads and bcam i should be around 265-270 hp huh?
89gfoxlx is offline
Old 03-12-2007, 04:35 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
ttt
89gfoxlx is offline
Old 03-12-2007, 07:58 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
alright what kind of hp gains with gt40p heads, gt40 upper and lower and tfs1 cam?
89gfoxlx is offline
Old 03-12-2007, 08:12 PM
ih8chevy
ih8chevy's Avatar
Default RE: Heads?
+1. the gains u would c with those heads will be real good. u could probably crest the 300 whp mark.
ORIGINAL: r.barn
ih8chevy is offline
Old 03-12-2007, 08:16 PM
89gfoxlx
89gfoxlx's Avatar
Default RE: Heads?
would i gain much more by porting and polishing the heads and intake?
89gfoxlx is offline
Old 03-12-2007, 08:20 PM
ih8chevy
ih8chevy's Avatar
Default RE: Heads?
yea u will.gt40 heads ported make really good power.
ih8chevy is offline
Quick Reply: Heads?
