1994 mass air
RE: 1994 mass air
The 94 had a 70mm MAF tube and 'F2VF' sensor.
If you want to use this MAF ona fox (A9* series computer), then you must still be using the stock 19lb injectors.
There are inletadapter plates available, but they can be tough to find. Basically it is a plate that will bolt to the 70mm MAF and allow you to use a slip fit inlet tube.
They should be about $35- $50.
That is the only change needed to run a 94-95 Mustang 70mm MAF on a Fox.
For comparison purposes the stock Fox MAF is 55mm.
jason
jason
