Compression
Old 03-14-2007, 10:39 PM
my77stang
my77stang's Avatar
Default RE: Compression
Once you know these things then any experienced engine builder could recommend the best compression ratio for your combo.
no matter what your combo, the higher the compression you can have and still run the gas and timing you want.... the better.
does that mean fine to run pump gas with a 12.5:1 ?
where did anyone say 12.5:1? you were talking a 408. a 408 stroker with flattops and your adverage head chamber size (64cc) you shouldnt be higher than 11.7:1 according to everything i have seen, which is really a little less than that because compression usually isnt is high as advertised unless your block is zero decked or sticking out the holes.
to get to around 10 you want approx 20cc dished pistons with a 64cc chamber head.
my77stang is offline
baddog671
07-26-2016 01:20 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bconboy
09-21-2015 12:52 PM
uberstang1
09-20-2015 06:42 PM
1st 4 eyed fox
08-24-2015 06:56 PM
Quick Reply: Compression
