wut is stroking?
RE: wut is stroking?
At least there are knowledgable people in here to help you....lol.[&:]
Stroking a motor increases the displacement. A 5.0 HO is a 302....4" cylinder bore X 3" rod length. You can stroke a motor using 3.25" rods or 3.4" rods (<--most common). If you keep the stock cylinder bore of 4" and add a 3.25" rod, you now have a 327" motor instead of 302. If add a 3.4" rod, you have a 342ci motor. If you bore the cylinder .030 over (making the bore 4.030") and add a 3.25" rod, you have a 331; or a 347 w/ a 3.4" rod.
As a side note: Shorter rods often allow you to (more dependibly) rev higher. Longer rods mean the pistons are traveling at much faster speeds at higher rpms and can cause a longer rod motor to wear out sooner. That doesn't mean a 347 won't last you 100k miles, it just means that a 331 driven under the same conditions as a 347 would probably outlast the 347.
W/ the new Boss 302 block, Ford says it can be bored up to a 4.125" diameter, meaning you could use a 331 stroker kit (w/ larger diameter pistons, obviously) and have a displacement larger than 347 using shorter rods.......
having your block bored .060 instead of .030 has nothing to do with rod length or stroke, but a larger diameter bore will yield a higher cubic inch displacement with any given stroke
http://www.fordmuscle.com/archives/2003/09/stroker/
this might help
you're confusing the bore and the stroke. the bore is how big around the cylinder is. think of looking at a pop can from the top; to make the top of the can bigger is increasing the bore. to make the can taller would be to increase the stroke. both increase the volume in different ways. as a side note, you dont bore a motor to gain displacement. a motor is bored to get a "new" cylindre wall to work with.
you should check that .060 over motor pretty well, as it may have overheating issues.
this might help
