30 lb injectors!!!!!!!!!!
#23
RE: 30 lb injectors!!!!!!!!!!
ORIGINAL: nit4gudtime
Well as i have posted that i was doing a h/c/i change with 30lb injectors on my 5.0, and was told by just about everybody that those injectors were way to big. Well i just finished installing everything and the car runs excellent. I couldn't be any happier with the performance gain.... Not rubbing it in that most of yall said it wouldn't work, but worked good, it idle's good with no problems over fueling......
you usually dont get into over fueling at idle until you hit 42lbs injectors.
btw: I'm running 24# injectors on my engine and it runs just fine except for a bit lean at 6,000+rpm.
glad to here the swap went good.
#24
I"d rather be fat(rich) as it be lean. Then you start having detonation problems when you run it lean. I realize i'm not using the full potential of the injectors but when i get the money to stroke it i wont have to buy another set of injectors.... I'm thinkin ahead for more mods.....
