need help asap fuel line disconect help!!!!!!
Old 03-18-2007, 07:00 PM
1995mustang818
1995mustang818's Avatar
Default need help asap fuel line disconect help!!!!!!
hey wats up guys im doing a cobra intake manifold swap on my friends notch can u guys tell me what i need to disconect the fuel lines from the intake manifold everything is ready to come out all i need is to disconect the fuel lines
thanx
Javier
1995mustang818 is offline
Old 03-18-2007, 07:04 PM
OnyxCobra
OnyxCobra's Avatar
Default RE: need help asap fuel line disconect help!!!!!!
Sears sells a fuel line disconnect tool set that works amazingly well, I took mine off in 2 seconds.
Edit: Lisle AC/Fuel line Disconnect Tool Set $9.99
OnyxCobra is offline
georgiaguy246
georgiaguy246's Avatar
you need a specialty tool. call autozone and ask them if they have the tool i am pretty sure that they do.
georgiaguy246 is offline
Old 03-18-2007, 07:06 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Special tool. Similar to any of these
PRO50SC is offline
Old 03-18-2007, 07:07 PM
1995mustang818
if i go buy the tool how do u use it
thanx
Old 03-18-2007, 07:09 PM
OnyxCobra
OnyxCobra's Avatar
For the one i posted you pick the right size depending on the fuel tube and snap it on, and then push the smaller end up inside and pull and it'll come apart, very easy.
Old 03-18-2007, 07:20 PM
1995mustang818
this is for the fuel line that comes out of the intake manifold i got the same exact set u posted up there
Old 03-18-2007, 07:24 PM
OnyxCobra
OnyxCobra's Avatar
ORIGINAL: 1995mustang818
mine had 2 fuel lines
Old 03-18-2007, 07:28 PM
5.0stanger
5.0stanger's Avatar
Mine has two also, both different sizes.
You don't have to undo the fuel lines to remove the lower, it is just easier. If you are swapping, you can just pull the rails and injectors out and leave them hooked up and in the car, then swap em.
5.0stanger is offline
Old 03-18-2007, 07:29 PM
1995mustang818
thanx alot u guys f***ing rock hahahaha
Quick Reply: need help asap fuel line disconect help!!!!!!
