mass air question
Old 03-22-2007, 12:57 AM
hunter5.0
hunter5.0's Avatar
Default mass air question
i just bought a 1989 mustang lx notch that was transplanted with a 5.0 it ran when i got it it seems to be done right and clean it didnt have oil pressure so i took it out and stroked it new aluminum heads bbk ssi intake 30lb inj 80mm throttle body , custom cam what concerens me is the car had no mass air sensor or wire where it should be. my question is does it need it or did someone not put the right harness in it . I assume it is a v8 harness due to the fact that it has 8 injector wires and it ran good any help would be great thanks
hunter5.0 is offline
Old 03-22-2007, 01:15 AM
LTnone
LTnone's Avatar
Default RE: mass air question
What year is the 5.0
LTnone is offline
Old 03-22-2007, 01:36 AM
vristang
vristang's Avatar
I suppose they could have converted the car to a 5.0 using Speed Density...
Check the catch code on the computer. The computer is behind the passenger side kickpanel.
jason
vristang is offline
Old 03-22-2007, 04:39 AM
Chitown racer
Chitown racer's Avatar
That stroker of your must be making some serious horsepowerto need an 80mm throttle body. Must be a track only car.
Chitown racer is offline
Old 03-22-2007, 06:35 AM
LTnone
LTnone's Avatar
Yikes...I didn't even catch that.
LTnone is offline
Old 03-22-2007, 09:15 AM
hunter5.0
hunter5.0's Avatar
what should i be looking at on the computer itself what is a catch code
Old 03-22-2007, 10:57 AM
vristang
vristang's Avatar
Catch code should read A9L or A9P if it is a MAF computer. Not sure what an SD code might be though...
It will be 3-4 digits, and should be in larger text/bold text, when compared to everything else.
jason
vristang is offline
Old 03-22-2007, 10:46 PM
hunter5.0
hunter5.0's Avatar
i looked at the computer and the numbers were as followed eec-IV under that was sfi-sd3 then to the right of those was E8SF-12A650-A1C and upper right corner read 8KC if this any help to you great thanks alot for your help
Old 03-22-2007, 10:55 PM
2 kwik
I ♥ Acer
2 kwik's Avatar
I think this was a conversation.. if some one took the cheap route and did and s/d you'll have some issue with that 80mm t/b which is huge and any off the shelve cam
2 kwik is offline
Old 03-22-2007, 11:45 PM
vristang
vristang's Avatar
ORIGINAL: hunter5.0
8KC is the catch code. My cheat sheet lists this as a Speed Density ecu from a Auto T-Bird.
vristang is offline
Quick Reply: mass air question
