what size TB and injectors?
motor specs:
-408w with 4340 forged flattop pistons/crank/rods & ARP hardware
-Canfield 195's
-Custom Grind street/strip cam
-TF intake manifold
what size TB and injectors do i need?
-Canfield 195's
-TF intake manifold
RE: what size TB and injectors?
I'm sure you would need to use an aftermarket FI system..I may be incorrect but in assuming he's using aftermarket then as stated I would inquire with the supplier as to components that would best suit your needs....standard mustang parts just won't apply to the 351.
dude if you have the knowledge to build a freaking 408 with good heads and a custom grind you should be able to have a good idea where to start.
what do you think this motor will need?
If you use someone like Jay Allen for just a hyd. roller cam, even on pump gas, I don't think it will be too difficult to get 450+rwhp out of this combo. I'd probably go right for a 42lb injector N/A.
In fact, some people are going to flip out when I use a 42lb injector on my N/A 10.5:1 347.
