any body here own a 347 stroker
just whant to see how many people have a 347 and how much hp, set up and 1/4 mile time [/align][/align]so if you have one don’t skip this post[/align]
RE: any body here own a 347 stroker
just finished installation of mine this weekend, its the best thing for a 302, besides a 331(favorite).
Just dont go over more than a .030 bore to the walls of the block, it was worth the time and money[:-]
what do you guys think about my set up -[/align][/align]-347 stroker- balanced for 28oz [/align]-billet steel flywheel28oz13lb[/align]-XFI cam[/align]-Trick Flow Track heat heads- 2.08 in 1.60 ex (intake runner was ported for new valve)[/align]-1.72 RR[/align]-Trick flow intake (street heat, I know I need a track heat but I need to sale mine first)[/align]-24lb injectors [/align]-75mm TB[/align]-75mm MAF[/align]-1 5/8 Mac equal length headers [/align]-2 1/2 exhaust whit flows[/align]-255lb fuel pump with regulator [/align]-3.55 gears ( I plan on going with some 4.10)[/align]- and a dino tune. [/align]
ORIGINAL: 89 mustang
what do you guys think about my set up -[/align][/align]-347 stroker- balanced for 28oz [/align]-billet steel flywheel28oz13lb[/align]-XFI cam[/align]-Trick Flow Track heat heads- 2.02 in 1.60 ex (intake runner was ported for new valve)[/align]-1.72 RR[/align]-Trick flow intake (street heat, I know I need a track heat but I need to sale mine first)[/align]-24lb injectors [/align]-75mm TB[/align]-75mm MAF[/align]-1 5/8 Mac equal length headers [/align]-2 1/2 exhaust whit flows[/align]-255lb fuel pump with regulator [/align]-3.55 gears ( I plan on going with some 4.10)[/align]- and a dyno tune. [/align]
+1,
1 3/4 LT's
1.6 rockers plenty. - I have the CompCams XFI "stroker" cam in my 351W w/ 1.6's, very nice
and they had to notch the sh*t out of my pistons with the 1.6 rockers.
Holley Intake is better or Trickflow R for a 347.
might want to get 30lbs injectors too, 24's not quite enough.
1 3/4 LT's
I have a 347 internal balanced (no counterweights) eagle 4340 lightened crank, 4340 rods, srp 9.0 :1 pistons. XFI stroker cam .608 lift .312 duration AFR 205cc 2.080 1.6 with the 75cc exhaust ports, fidanza 11lb flywheel, for now cobra intake, 24lb injectors, revs to 8000rpm. msd digital 6, blaster coil and dist. 1.6 full RR, 3.73's mac equal lenths shortys, off road h-pipe and mac one chamber race mufflers. runs like a million bucks haven't been to the track yet anyone have an opinion on what my car will run? not to steal your post or anything, basically same question but i'm not sure what compression ratio you are running thanks.
