stroking a 302
stroking a 302
Is it possible to be able to stroke your car with stock pistons??i want to do a bottom end i know i need bearings piston rings etc... do i need to change pistons??do they sell kits without pistons???i think stroking the motor means changing the length the pistons travel by changing the crank and/or rods...so is it possible?
RE: stroking a 302
talk to FullAuto he sells strokers through the forum. also check out coasthigh performance i think the website is coasthigh.com
technically yes there is a way to stroke the motor without having to bore it.
how many miles is on the car?
RE: stroking a 302
almost 170k but doesnt knock or ping or overheat, i want to pull out the 302
change the bearings piston rings and theres a rebuild kit for that but i was wondering since my stock pistons are ok if i could just invest in a stroker kit that has what i need without spending more on boring otherwise id consider a 351w swap...
