AOD gears?
#26
RE: AOD gears?
[quote]ORIGINAL: 91RedHatchback
so let me get this straight...if you are planning to put in a supercharger on your car, 4.10s wouldnt be a good choice? why not? why would you go lower then?
[/quote
you will run out of motor
i know cause im there 4.10's + 28" dr's + 125shot = 11.51 trapping 5500rpms. and nitrous pulls your peak power down4-600 rpms . my peak power is 4000rpms. damn stock longblock[:@]
[/quote
#27
RE: AOD gears?
ORIGINAL: 92hatchLX
Bob's just mad because he bought an expensive AOD tranny and something went wrong with it
I bought 3 of those MF'ERS !!!!!!!!!!!! and they all broke and they all sucked
none were lentech though. i'm very anti-aod
#28
RE: AOD gears?
also, w/ a blower you are in your powerband for a longer time, the hp curve is up, runs across for a while b4 it drops, so you don't "need" the gear to get there.
a 5-speed blower car likes 3.27or 3.55 depending on the rest (higher hpwants lower numerical gear)
the whole idea is using leverage to get your car in the powerband and keep it there
#30
RE: AOD gears?
This might be a stupid question to ask but will 4.10 gears make your cars temperature climb since after all at highway speeds you all say that its running at a higher RPM... or will any bigger gears do that? Im just wondering because my car constatly runs at about 3/4s of the temp.... sometimes at peak!
